Tenemos 27704 miembros registrados.El último usuario registrado es Jefferson_Diaz.
Nuestros miembros han publicado un total de 537100 mensajes en 37211 argumentos.
Gilera g1 250 racing - o - Rouser 220
Página 2 de 4. • Comparte •
Página 2 de 4. • 1, 2, 3, 4
Re: Gilera g1 250 racing - o - Rouser 220
Gilera manual
http://www.massimomotor.com/CGI-BIN/pdf/YG3R-MANUAL.pdf
Info de la NX250
The Honda NX250 was a new concept produced by Honda, a crossover dual-sport motorcycle available in the USA from 1988 thru 1990. It is a lightweight bike intended for both on-road and off-road riding. It was never produced by Honda in substantial numbers, but was met with generally positive reviews with its perfect balance of power, size, and style.
The NX250 featured an all new compact, liquid cooled, 249 cc, single cylinder, four-valve, D.O.H.C, four-stroke engine with electric start. 26 hp (19 kW) at 8,500 rpm, at 11 to 1 compression ratio, 2.4 Kgm torque at 7,500 rpm. It had a bore and stroke of 70.0 × 64.8 mm (2.76 × 2.55 in) and a six-speed transmission.
The NX250 averages 70 miles per US gallon (3.4 L/100 km; 84 mpg-imp) , fuel capacity is 9 litres (2.4 gallons including reserve) with refills needed at around 130 miles (210 km). The NX250's maximum speed (per speedometer) is 95 miles per hour (153 km/h) , though it has been known to be capable of speeds nearing 100 miles per hour (160 km/h), and it is both quick and agile. The suspension is 37 millimetres (1.5 in) forks with 8.7" travel up front, and Pro-Link with 7.9" in the rear. It has a 1,350 millimetres (53 in) wheelbase and a dry weight of 118 kilograms (260 lb) . The seat height is 820 millimetres (32 in) .
It was only available in two colors, Metallic Blue and Pearl White. In some countries Honda continued production of the NX250 up to 1993, it was named "Dominator" and came in various other colors.
Saca tus conclusiones
Info de la NX250
Perdona jorgito, pero vos saca tus concluciones pero nosotros los usuarios de BAJAJ ya las sacamos y por eso la tenemos, me parece que si a vos te convence la gilera dale para adelante, en este club hay varios que no tienen BAJAJ, y para nosotros es bueno que asi sea porque sobre todas las cosas es un club de amigos, y los consejos que te dan son de amigos que quieren que elijas lo mejor para vos que haces la consulta, asi que si te convence la gilera dale para adelante, y si te sale buena mejor, pero si te equivocas, igualmente vamos a estar dandote una mano.
UN ABRAZO
UN ABRAZO
juanma41- Cantidad de envíos : 276
che pero nose porque lo bardean .. la mayoria de los motores chinos son copias de motores viejos honda, es como q pasado el tiempo dejan de tener derechos y se pueden copiar, la verdad no la se lunga pero es algo asi.. sino de donde se creen q salen todas las 125 y 150 chinas!! los chinos no inventan nada, copian!, eso si no te pueden hacer el mismo motor del fireblade 2011 te hacen motores del año del pedo y con menos calidad .. yo le pongo otra ficha a la gilera esa a mi me gusta
- Cantidad de envíos : 11413
Gracias Shor y juanma41
Hay que comprender que el mercado y los modelos de motos cambian constantemente
Tengo un amigo que tiene la bajaj 200, es un administrador de este foro
Nunca dije que la bajaj es mala moto, al contrario se que es buena
Pero pregunto, que les decian a los primeros compradores de bajaj en el pais??
Eso es una bosta es india, la fabrican con madera
Yo mismo trabajando en el puesto he desembarcado camiones TATA y 4x4
Son indios, un asco en mayuscula
Y traian motor copia con licencia de mercedes
Pero no por ello todo lo indio es malo
Se comprende?
Bueno gente, deje en claro que iria por la G1
GazzZ
Vendiste la 200 con 9000?
Eso no es garantia que algo es bueno, si me dijeras mas de 50.000 km te creo
o al menos 30.000
Igual ya sabes que podias tener la 200 muchos miles y no ivas a tener problema
Les dejo un link de un video a 155 km/h a 8200 rpm, aprox
https://www.youtube.com/watch?v=Jb-xFM-unSc
Y una imagen del instante de los 155 km/h esta a los 2,16 minutos
Error del velocimetro entre 5 y 8 km/h
Sepan que no estaba ablandada, tenia solo 250 km recorridos
peter- Cantidad de envíos : 665
Bamos a esperar a que la tenga el amigo jorgito, y luego de que nos mustre su maquina en fotos, nos sacaremos las dudas en el foro y personalmente en alguna juntada.
Vamos a esperar a que la tenga el amigo jorgito, y luego de que nos muestre su maquina en fotos, nos sacaremos las dudas en el foro y personalmente en alguna juntada.
siiii,para cuando la gile en el club jorgito?????
fabian_castro- Cantidad de envíos : 572
Peter
Es diseño original honda
No vibra
Los mismos usuarios lo alagan
Y muchos usuarios fueron sufridores poseedores de otras gileras
No vibra
andaba acentantando la 180 mia en la ruta 74( entre juares y tandil)con 400kms tambien andaba uno acentando la gillera en cuestion (yo estaba fumando al costado de la ruta) paro miro la 180 ,me comento q se decidio por la gilera ,q le habian ofertado la 220 , creo q me la cambiaba me parece q el vago se arrepintio de su compra me decia ;"son buenas enserio che .... q lindo suena....esta bueno el tablero.... y a cuanto venias ? " y la verdad no me parecio mejor tan siquiera q la 180 tornillos del carenado medio cruzados demaciado plastico fulero que se yo .. cuando paro los electros estaban a full (o el electro, no se ) cuando le dio arranque no regulaba debio ser "una carburita en el basurador " por ultimo me pregunto a mi si su moto refrijeraba con aceite o agua ,casi seguro que vago a esa altura la cambiaba por una smash sin muchas vueltas ,la pago 15 lucas me dijo ,creo q una locura
papa, mama...; boca,river...,radical ,peronista ...,zanella,gillera ...honda ,yamaha..
Edad : 72
Localizacion : aca
Gaucho
Era una Gilera G1 o una gilerucha cualquiera??
Te paso el comentario de un usuario de una Rouser 200
http://www.club-bajaj.com/t4291p170-nuevos-modelos-gilera-g1-250-rr-y-r
Te paso un link de usuarios de la gilera g1
http://www.psicofxp.com/forums/en-dos-ruedas.529/1102481-nueva-gilera-g1-250-rr-parte-3.html
digan lo que digan , las motos chinas vienen con materiales de mala calidad en gral y malas terminaciones,, se aflojan todas , y si las dejas al sol se descolorean ,, de ser azul pasan a ser celestes, de rojas a bordo, y si cada tanto no ajustas los tornillos , los terminas perdiendo ,, y a mi no me corran con giladas,, que se bien de lo que hablo. mi señora tiene una 125 china y gaste mas plata en la bulonera que en nafta,, asi que otro perro con este hueso.. si anda 10 kms mas o menos la g1 me calienta un huevo,, pero de mi bajaj solo pasaria a una yamaha , honda , kawa o suzuki, ni a palos vuelvo atras en calidad de moto por 10 kms mas de vel.. al que le guste que se la compre esta o la que quiera,, total la plata no sale de mi bolsillo,,,
r65- Cantidad de envíos : 497
no digo q sean malas digo q el tipo estaba incomodo desconforme con su moto le costaba arrancar y como conte no regulaba sera tal ves, prejuicio mio tuve una gilera 200 (china )q la devolvi va.. la tire en la ajencia con 52 kmts y el amortiguador agarrado como piedra, perdi plata y me traje una mondial hd 250 (china)y de nuevo otro problema a 85-90 en la ruta de M.D.P a tandil cuando tomaba velocidad vibraba tanto q dificultaba mirar por los espejos (un castigo)la vendi antes de 4 meses y antes de terminar de pagarla!!!;hace 2 semanas se fue un amigo de vacaciones a la costa me llamo para ir a buscralos esposa ,amigo,y mondial 200 (carenado similar a la g1) tambien vino un enano a los garrotasos adentro de la moto ,se entiende no?.jorgito escribió:Gaucho
noblesa obliga, tuve una zanella hj 125 ,exelente moto.
Edad : 72
Localizacion : aca
El cuadro de la g1 es el mismo de la Mondial rd200
Pero lo que hace vibrar a la moto es el motor
Segun los usuarios ( que algunos tubieron gileras vibradoras anteriormente)
comentan que no vibra, solo comentan que a 140 es sensible a los desniveles del piso, o sea, el manubrio lo tenes que llevar firme
por el resto todo bien
Pero bue, no voy a comentar mas, se que es un foro de bajaj, y porsupuesto que van a odiar a las chinas
Solo les dejo mis comentarios de usiarios y datos reales de la moto en si, sin perder objetividad por los sentimientos
La bajaj es de muy buena calidad, muy superior a la calidad de gilera, solo destaco este modelo que se distingue del resto de las gileras, hasta los mismos usuarios les sacan el calco de la burbuja, indica que les da verguenza que diga gilera ( si ven las fotos podran verificar lo que les digo)
aca hay un usuario q la tiene .. preguntale porq la quiere cambiar por una 220 .. es ese q anda preg por si viene la 220 racing en gris, por algo debe ser el cambio algo malo debe tener la g1 como para hacer ese cambio..
les digo algo... yo apostaria a la g1... no digo q sea mejor q la bajaj... pero... me gustaria subirme a una y ver q tal responde
larvosin- Cantidad de envíos : 1040
Les dejo otro videito
a 160 de tablero
Segun gps a 145=128
Por mas error, aprox 140 reales
Y con 2 personas !!
https://www.youtube.com/watch?v=MBLPgFriI9I
a 160 de tablero
Segun gps a 145=128
Y con 2 personas !!
esa es la q me gusta la naked! la carenada tendria q dar un poco mas por la aerodinamia tonces a cuanto camina?? q lindo motor la verdad ojala te compres una tocayo asi nos cerras la boca a todos, seria lindo
Si es como vos decis de esta maquina, espero que la tengas pronto.
PD: Todavia estas indesiso con la eleccion o te faltan un par de chirolas?
habria q preguntarle a canichenegro q alababa ala g1, es administrador en psicofxp y facebook en el tema gilera g1, y ahora anda por aca preguntando por la rouser 220 gris!!
yo estaba la misma discucion pero opte por la rouser. y supero ampliamente mis espectativas.
juanma d q parte de merlo sos?
FRAN- Cantidad de envíos : 393
te mando un mp
Por lo que lei y las prestaciones mas la modernidad de sus componentes sigo apostando por BAJAJ asi que me quedo con la 220cc ya que me parece una moto muy buena y no una falsa pistera como las demas, en ese caso si quiero comenzar con una moto tipo pista me tiro por la Hyosung 250cc y cuento terminado... saludos !!!
Si tenes la plata para la Hyoncung, ni pensarloxerealkiller escribió:Por lo que lei y las prestaciones mas la modernidad de sus componentes sigo apostando por BAJAJ asi que me quedo con la 220cc ya que me parece una moto muy buena y no una falsa pistera como las demas, en ese caso si quiero comenzar con una moto tipo pista me tiro por la Hyosung 250cc y cuento terminado... saludos !!!
Con esa plata te compras una 220 y una g1
Lo mejor del mercado relacion precio producto a 14 lukas
La bajaja 220 y la Gilera G1
Lo demas es mas plata por lo mismo, YBR CBX
Hola a todos, les cuento que soy un feliz propietario de una G1 rr 250, me parece que nadie puede criticar una moto a la cual no conoce en cuanto a su andar, por eso solo puedo hablar de mi moto, aunque la bajaj en cuestion es muy linda.
yo les puedo contar que mi g1 anda muy bien, es muy comoda, anda rapido, no es cara, en definitiva es muy buena moto, ademas de linda. muchas pesonas no se animan a contar los defectos de su moto por que se sienten como que reconocen que hicieron una mala compra, pero la idea es decir la posta.
los contra que le encontre a mi g1 son los siguientes, muy dificil de conseguir repuestos ya que es una moto fuera de serie (carenado luces y algunas otras cositas), se aflojan muchas cosas pero nada que una buena y definitiva apretada no cure, yo me tome el trabajo de repasar los tornillos y tuercas y nunca mas se aflojaron. otra cosa que le encontre es que las luces delanteras tienen un sistema de sujecion de lampara muy malo, yo lo arregle con una gotita de pegamento y anda genial. otra cosa mala que le encontre es que la cubierta trasera con las que viene patina un poco, la moto frena genial doble disco delantero y trasero simple, igual frena muy bien solo ese detallito. cualquier duda que tengan al respecto sobre la G1 no duden en consultar.
joxtcp- Cantidad de envíos : 17
Fecha de inscripción : 31/05/2011
Te hago una pregunta.
Vos decís que hay tornillos flojos pero es cuestion de ajustarlos.
Entonces el problema es de la gente que ensambla la moto que no apreta bien las cosas?, o te parece que el motor vibra como para aflojarlas?.
Lo de las cubiertas nos pasa a todos, las de las indias tampoco son tan buenas como comentan, y a mi tambiém me pasó que me patine.
Lo mismo pasa con los repuestos, hoy en dia que no se consigan repuestos no quiere decir nada, porque no se estan consiguiendo cosas para las motos en general.
q aporton de joxtcp.. ahora te voy a cagar a preguntas jajajaj
primero bienvenido esto es un foro de motos mas alla de la marca de las mismas..
segundo q velocidad de gps te da crucero y final?
tercera no te parece mucho el RR ? a mi me suena a marqueting.. RR es un pura sangre!!
a mi me encanta la naked.. en una de esas me terminan convenciendo..
Página 2 de 4.
» Presento Honda CB500F!!! Un sueño
» Se me clavo el motor a los 11mil km (consulta)(FOTOS)
» Falla motor, tironeo y ruido lado magneto
» Se descabezo una válvula con 3000 km y a 5000 rpm en 4ta
» problema tironeo
» manual de taller ? regulacion TPS
» Vendo Rouser 220F noviembre 2016 equipada completa
» Hola.
» Hola Soy Daniel
» Consulta tornillos contrapesos Rouser 135
» Buenas
» Quitar soporte porta patente y guiño trasero
» Hola, me presento
» Pintura tanque
» Duda con el estado de mi moto.
» FALLA EN RANGO MEDIO DE RPM Y SE PARAAAA...!!!
» Vendo la colo - AS200 - 2017 - 17000km
» Presentacion Saludos desde Colombia
» Hola!!
