NUEVA R15 version 2.0
+36
maurix
Lukas_u2
COLO 220
Enchufadoal220
juan
freddy
ramiro47
como-relampago
RODA
MFK08
Fer-NA!
220_silver
max_avatar
sismo
Zóltan
alfie
leonelspike
Alejandro A
mariano reales
javi_moto
Javier2556
Yayi
p1n1983
RoLiNgA
fer2
Dani220s
GERMAN DE RAFAELAp
JaviMdq90
VICTORYBR
MaurSs
darios
Foxhound
40 participantes
Página 1 de 2.
Página 1 de 2. • 1, 2
Re: NUEVA R15 version 2.0
DAME DOS!!!
Esstaa Hermosisisisima.. Todo bien que no ande como la 220 Es esperado.. Pero para el motorcito 150 Anda tremendo... Al igual que la Fxr 150 de Suzuki.. Andan que dan calambre siendo un motor 150.. Y la estetica de esta R15.. Hace que se me caigan las babas..! ^^
Fer-NA!- Cantidad de envíos : 294
MUY BUEN APORTE FOX
PELUCA SABEEEEEEEE
PELUCA SABEEEEEEEE
si no me equiboco la suzuki fxr 150 tiene 20cv
dejo ficha tecnica de la fxr para comprar
Model: Suzuki FXR 150
Year: 2001
Category: SportRating:68.2 out of 100.
Displacement: 147.00 ccm (8.97 cubic inches)
Engine type: Single cylinder
Stroke: 4 Power: 20.11 HP (14.7 kW)) @ 13000 RPMMax
RPM: 15000
Compression:10.7:1
Bore x stroke:62.0 x 48.8 mm (2.4 x 1.9 inches)
Fuel system: Carburettor. Mikuni BS2955
Valves per cylinder: 4
Fuel control: DOHC
Ignition: CDI, 9 degree BTDC at 1500rpm
Starter: Electric & kick
Lubrication system: Wet sump
Cooling system: Oil & air
Gearbox: 6-speed
Transmission type final drive: Chain
Clutch: Wet multi-plate type
Physical measures
Dry weight: 118.0 kg (260.1 pounds)
Seat height: 760 mm (29.9 inches) If adjustable, lowest setting.
Overall height: 1,080 mm (42.5 inches)
Overall length: 1,985 mm (78.1 inches)
Overall width: 665 mm (26.2 inches)
Wheelbase: 1,325 mm (52.2 inches)
Chassis and dimensions
Rake (fork angle): 24.0°
Trail: 85 mm (3.3 inches)
Front suspension: telescopic, coil spring, oil damped forks
Rear suspension: swinging arm, coil spring, oil damped, spring pre-load 4-way adjustable
Front tyre dimensions: 80/90-17
Rear tyre dimensions: 100/90-17
Front brakes: Single disc
Rear brakes: Single disc
Speed and acceleration
Top speed: 150.0 km/h (93.2 mph)
Power/weight ratio:0.1704 HP/kg
Other specifications
Fuel capacity:15.00 litres (3.96 gallons)
Reserve fuel capacity:3.40 litres (0.90 gallons)
Fuel consumption pr. 10 km (6.2 miles):3.00 litres (0.79 gallons)
Year: 2001
RPM: 15000
Compression:10.7:1
Fuel control: DOHC
Gearbox: 6-speed
Physical measures
MFK08- Cantidad de envíos : 444
Fecha de inscripción : 12/02/2010
Localizacion : Villa Maria
Por lo que se tiene 18.. xD Pero asi mismo es un caño.. Un amigo la tiene y la he manejado y es impresionante lo que tira.. Ni se parece a un 150.. Lo unico que no me gusta de la moto.. es el ruido a lata del escape original..! xD
Esta Hermosa es R15
Es un tema el r15, mucha facha, pero rueda chica y sale una locura, con esa plata pinta un fz16 y listorti :S
muy linda la moto, pero muy cara para un 150
como-relampago- Cantidad de envíos : 116
Localizacion : Buenos Aires - Chascomús
Es hermosa!! le pusieron la cola como la r125.
ramiro47- Cantidad de envíos : 245
Localizacion : Ramos mejia
muy linda cambiaron ese colin de 110 que traia!! pisterita pisterita quedo!!! led tambien simil carbono(parece) mejoro mucho la estetica !!! creo que tiene la misma potencia que la anterior hay que ver ..
Localizacion : posadas
hermosa como toda yzf aca las traen chipeadas donde compre mi ys..pero vale 26 lukitas..me dejo heladooo...cuanto puede mejorar chipeada?? no sabia que en las motos tmb sde hace eso..
juan- Cantidad de envíos : 599
juan escribió:hermosa como toda yzf aca las traen chipeadas donde compre mi ys..pero vale 26 lukitas..me dejo heladooo...cuanto puede mejorar chipeada?? no sabia que en las motos tmb sde hace eso..
Estaria bueno averiguarlo... hay un amigo en el club que tiene una R15 (modelo anterior), capaz ya sabe.
Alejandro A escribió:juan escribió:hermosa como toda yzf aca las traen chipeadas donde compre mi ys..pero vale 26 lukitas..me dejo heladooo...cuanto puede mejorar chipeada?? no sabia que en las motos tmb sde hace eso..
yo acompañe a un amigo para averiguar por esa porq le gusto y le djeron asi..23 o chipiada a 26..me parece medio raro..mañana si hago tiempo pasa a que me digan bien
Una maquina muy superior en muchos aspectos
sismo- Cantidad de envíos : 62
Fecha de inscripción : 03/08/2010
Localizacion : Colombia
pregunta: si esta chipeada quiere decir que es a inyeccion?? o se le modifica el cdi para que llegue a la zona roja del tacometro?? o es un verso argentino para sacarte mas plata???
para los usuarios que quieran pasar de la 135 a la ninja 250, este parece ser un paso previo tal vez!!! es una hermosura la guacha pero chipeada y 10 lucas menos!! choros!
SI ES ESPECTACULAR MUY LINDA PERO ES 150 Y DA 140KM CON TODA LA FURIA Y OBVIAMENTE Q CON VIENTO O TORNADO A TU FAVOR SINO DE 100 NO LA SACAS POR ESO AGUANTE EL ROUSER 220!!!!!!!! ES LA Q VA!!!!
ES PARA LA CIUDAD PARA HACER FACHA SI QRES RUTEAR RAUSER 220 TE VAS COMO LOS MEJORES JAJA
COLO 220- Cantidad de envíos : 4
Fecha de inscripción : 23/04/2012
Localizacion : RAMIREZ, ENTRE RIOS, ARGENTINA
Ta Aaaarrrrrmosaaaaaaaaaa!
Colo, yo con relacion 16-43 toque los 140 de tablero en la 135, con viento a favor obviamente, pero el dia estaba demasiado soleado como para q hallan tornados, jajaja! ;D
Lukas_u2- Cantidad de envíos : 164
Fecha de inscripción : 07/12/2011
Localizacion : La Plata
yo tengo la misma duda, l puse a mi motomel un microprocesador intel medio viejon pegado al tanque y anda igual, o tiene que ser un chip?jejefreddy escribió:pregunta: si esta chipeada quiere decir que es a inyeccion?? o se le modifica el cdi para que llegue a la zona roja del tacometro?? o es un verso argentino para sacarte mas plata???
maurix escribió:yo tengo la misma duda, l puse a mi motomel un microprocesador intel medio viejon pegado al tanque y anda igual, o tiene que ser un chip?jejefreddy escribió:pregunta: si esta chipeada quiere decir que es a inyeccion?? o se le modifica el cdi para que llegue a la zona roja del tacometro?? o es un verso argentino para sacarte mas plata???
disculpa que te corrija pero no es motomel, es motomiel...
hablando en serio creo que un amigo colombiano que esta en el foro tiene una r15 potoqueada, o sea chipeada y demas yerbas. Fijense en el buscador, ahi tambien se habla de la r15. Para mi ya lo dije: un absurdo total comparar una moto con todas las caracteristicas que tiene la Yamaha r15 (chasis deltabox, ciclistica, componentes, tecnologia, etc) con cualquier otra moto. Con la unica moto de aca que se podria comparar es con la suzuki fxr150, si no me equivoco no hay otra racing de tan baja cilindrada. Compararla con la 220 me parece un error de aca a jupiter ida y vuelta 80 veces.
estoy de acuerdo con vos que no se pueden comparar la r 15 y la 220, no estan destinadas al mismo publico, y por lo de motomeil, nose a mi me lleva y me trae todos los dias, jeje y desde que le puse el intel anda mas serena, jejeje(nada que ver) fuera de joda, que es chipeada? que viene con chips de chocolate? todos se hacen los boludos y no contestan, jejeAlejandro A escribió:maurix escribió:yo tengo la misma duda, l puse a mi motomel un microprocesador intel medio viejon pegado al tanque y anda igual, o tiene que ser un chip?jejefreddy escribió:pregunta: si esta chipeada quiere decir que es a inyeccion?? o se le modifica el cdi para que llegue a la zona roja del tacometro?? o es un verso argentino para sacarte mas plata???
ESTAS MUY EQUIVOCADO !!! NO ESTAS USANDO EL CHIP ADECUADO , YO USE EL CHIP CLARO DE MI CELU EN LA NINJA Y CAMBIO UN MNTON AHORA ANDA A 200 KM/H .maurix escribió:yo tengo la misma duda, l puse a mi motomel un microprocesador intel medio viejon pegado al tanque y anda igual, o tiene que ser un chip?jejefreddy escribió:pregunta: si esta chipeada quiere decir que es a inyeccion?? o se le modifica el cdi para que llegue a la zona roja del tacometro?? o es un verso argentino para sacarte mas plata???
OJO QUE CON EL DE MOVISTAR DICEN QUE 210 SE PONE !
yo uso nextel, si le pongo ese chip que tal andara? mejor no, me va a hacer prip cada 10 kmculito escribió:ESTAS MUY EQUIVOCADO !!! NO ESTAS USANDO EL CHIP ADECUADO , YO USE EL CHIP CLARO DE MI CELU EN LA NINJA Y CAMBIO UN MNTON AHORA ANDA A 200 KM/H .maurix escribió:yo tengo la misma duda, l puse a mi motomel un microprocesador intel medio viejon pegado al tanque y anda igual, o tiene que ser un chip?jejefreddy escribió:pregunta: si esta chipeada quiere decir que es a inyeccion?? o se le modifica el cdi para que llegue a la zona roja del tacometro?? o es un verso argentino para sacarte mas plata???
Muy linda la verdad.. Ahora, medis 1.90 te compras una moto de esta caracteristicas y pareces que vas arriba de esas zanellitas nuevas pisteristas que salieron que son una patada en los huevos..
fedeale- Cantidad de envíos : 277
Localizacion : asd
fedeale escribió:Muy linda la verdad.. Ahora, medis 1.90 te compras una moto de esta caracteristicas y pareces que vas arriba de esas zanellitas nuevas pisteristas que salieron que son una patada en los huevos..
Si te fijas en el buscador capaz que sale, un amigo del foro se habia comprado una y era grandote, me acuerdo que habia subido fotos y todo, no lo busco porque me da paja...
era la primer r15, o sea la 1.0
con respecto al tema del chip es facil la explicacion: vos seguramente tenes un celular que usa chip de alguna empresa de telefonia, sea cual sea la compania vos podes ponerle tu chip del celu a la moto y hacer que esta mejore su rendimiento, aumentando la potencia y consiguiendo mayor velocidad final.
Alejandro A escribió:fedeale escribió:Muy linda la verdad.. Ahora, medis 1.90 te compras una moto de esta caracteristicas y pareces que vas arriba de esas zanellitas nuevas pisteristas que salieron que son una patada en los huevos..
haaaa...pero te sirve en lugares donde no tengas señal?
Y no... pero por ejemplo si te vas a Ibicuy en entre rios no necesitas mas velocidad final, no vas a tener señal y no te va a andar la moto chipeada, pero vas pistear como un patronelli por un sueño
maurix escribió:estoy de acuerdo con vos que no se pueden comparar la r 15 y la 220, no estan destinadas al mismo publico, y por lo de motomeil, nose a mi me lleva y me trae todos los dias, jeje y desde que le puse el intel anda mas serena, jejeje(nada que ver) fuera de joda, que es chipeada? que viene con chips de chocolate? todos se hacen los boludos y no contestan, jejeAlejandro A escribió:maurix escribió:yo tengo la misma duda, l puse a mi motomel un microprocesador intel medio viejon pegado al tanque y anda igual, o tiene que ser un chip?jejefreddy escribió:pregunta: si esta chipeada quiere decir que es a inyeccion?? o se le modifica el cdi para que llegue a la zona roja del tacometro?? o es un verso argentino para sacarte mas plata???
Los autos modernos poseen una computadora que controla la inyeccion, la curva de avance o chispa de bujias y en el caso de los autos con turbocargador, la presion de este. El cerebro de todo motor actual es la computadora o Unidad de Mando tambien conocida como ECU. Adentro de dicha computadora se encuentra un chip, en donde reside el programa original con el que se dan las ordenes al motor.
¿Que es lo que cambia un chip de potenciacion?
Suministro de combustible, curva de avance o chispa de bujias y presion del turbocargador cuando el motor no esta trabajando en marcha minima. Una serie de mapas residen en el chip de la Unidad de Mando que controlan esos parametros. A traves de extensas pruebas de manejo y dinamometro, el fabricante desarrolla un programa original para cada auto, en donde pone especial interes en consumo de combustible, emisiones contaminantes, tipos de combustible en donde el auto se vendera, potencia deseada segun sus objetivos, gobernadores de velocidad maxima segun el tipo de llantas que montaran en cada auto, etc. Cuando se modifica un chip, se alteran esos mapas con el objeto de obtener mayor potencia y torque, y mayor velocidad final si el auto tiene gobernador. El resultado es un auto mas agil en cualquier condicion de manejo, libre de efectos negativos colaterales. Es por ello que en Europa, EEUU y ahora en Argentina, el chip es una de las modificaciones mas populares y sencillas cuando se trata de optimizar el desempeño de un motor.
En cuanto al aumento de Caballos de Potencia queda sujeto al fabricante y modelo de vehiculo. Sin embargo, como referencia general en vehiculos a inyeccion directa que no posean turbos de fabrica el aumento puede llegar hasta un 12% adicional. Por ejemplo, Vehiculo de 130HP X 12% = 15.6HP adicional, lo que se traduciria que el vehiculo quedaria en 145HP aproximadamente. Para el caso de los vehiculos que posean turbos originales de fabrica el aumento podria llegar hasta un 22% adicional.
Guillote27- Cantidad de envíos : 118
Localizacion : San Rafael, Mendoza
Muy buena moto, la recomiendo al 100%, la mia ya va a cumplir casi 3 años y aun sigue siendo una buena propuesta
es hermosa pero yo la pongo en la repisa porque para subirme hace de cuenta que ando en triciclo... jajajaj
ojo no piensen mal ehhh... que me gusta mucho la motito hasta la r6 no paro
Antes quería que llegue la R15 2.0, pero desde que tengo la 220 no pienso bajar de cilindrada, si llegase a venir no la compraría, prefiero mi rusita :) Parece una r6 y no pasa los 150...
Luca Zepp- Cantidad de envíos : 402
Localizacion : Florida
» Nueva versión de 200NS
» Nueva Dominar versión 2019?
» vale la pena? Dominar 2019/2019 II.(NUEVA VERSION)
» Comprar Honda Twister cb250 nueva y/o Dominar 400 nueva
» Balizas en Rouser 135 Version 2.
Página 1 de 2.
