NUEVA PULSAR 200SS ????
+7
JACK-CROMAX
jechu13
R200
MrOtto
SebaT
♏㋡ℕ㋡
11 participantes
Re: NUEVA PULSAR 200SS ????
Mirando mejor el video, es una moto electrica se llama Energica EGO es italiana:
TECHNICAL SHEET
MOTOR
TYPEPERMANENT MAGNET AC (PMAC), OIL COOLED
POWER100 kW FROM 4900 rpm TO 10500 rpm
TORQUE195 Nm FROM 0 TO 4700 rpm
BATTERIES
CAPACITY11.7 kWh
LIFE1200 CYCLES @ 80% CAPACITY (100% DOD)
RECHARGE3.5h (0-100% SOC) Mode 1-2 or 3 charge, 30 min (0-85% SOC) Mode 4 DC Fast Charge
WHEELS
FRONTMARCHESINI FORGED ALUMINUM 3.5″ X 17″
REARMARCHESINI FORGED ALUMINUM 5.5″ X 17″
TYRES
FRONT120/70 ZR17 PIRELLI DIABLO ROSSOII
REAR180/55 ZR17 PIRELLI DIABLO ROSSOII
FRAME
FRAMETUBULAR TRELLIS
SWINGARMCAST ALUMINUM
BRAKES
FRONTBREMBO, DOUBLE FLOATING DISCS, Ø 320MM, 4 PISTON RADIAL CALIPERS
REARBREMBO, SINGLE DISC, Ø220MM, 2 PISTON CALIPER
ABSBOSCH SWITCHABLE
SUSPENSIONS
FRONTMARZOCCHI Ø43MM, ADJUSTABLE REBOUND AND COMPRESSION DAMPING, SPRING PRELOAD
REAROHLINS, ADJUSTABLE REBOUND AND COMPRESSION DAMPING, SPRING PRELOAD
TRANSMISSION
Reduction gear ratio (secondary)2,75
CHAIN525 0-RING
PERFORMANCE
MAX SPEEDLIMITED AT 240 km/h
RANGE150 kM @ 80 km/h – 190 km @ 60 km/h – 100 km @ 100 km/h – 50 km ON RACE TRACK
DIMENSIONS/WEIGHT
SEAT HEIGHT810 mm
WHEELBASE1465 mm
WEIGHT258 kg
LENGTH2140 mm
HEIGHT1140 mm
WIDTH720 mm
ELECTRONICS
Power electronics water cooled
Vehicle Control UnitA Vehicle Control Unit implementing a multi-map adaptive energy and power management algorithm manages the vehicle. During drive, system carefully monitors and trims 100 times per second the motor’s power, starting from; throttle command; chosen engine map; battery status and speed. System also handles regenerative engine braking and regenerative electrical brake, interfacing with the ABS unit. This allows for a superb efficiency in battery energy management and a great drive performance and experience. It constantly monitors batteries, even in key off position in order to ensure battery protection even in long winter storage. Vehicle Control Unit is based on a redundant architecture in order to grant the state of the art of safety and performance.
CONNECTIVITY
The vehicle is equipped with a communication platform based on the Bluetooth and UMTS / GPRS Standards .
The vehicle is able to offer “short range” and “long range” connectivity services. In particulary:
- Short Range Connetivity: Bluetooth 3.0 Module, range 100m;
- Long Range Connetivity: LTE/ UMTS/GPRS Module, SMS, TCP/IP, FTP, SOCKET, HTTP Comunications
CHARGER
Onboard, 110-220 V 50-60 Hz 3 kW, with pilot signal for Charge Stations Interface
DASHBOARD
4.3″ WQVGA TFT Color Display with Internal memory for datalogging, Integrated GPS receiver and Bluetooth communication
REVERSE MODE
FOR EASIER HANDLING AT VERY LOW SPEED
COLORS
MATT PEARL WHITE, MATT BLACK
This data sheet is provided for reference only. CRP Racing reserves the right to substitute or change components.
FOTO:
TECHNICAL SHEET
MOTOR
BATTERIES
CAPACITY11.7 kWh
WHEELS
TYRES
FRAME
BRAKES
ABSBOSCH SWITCHABLE
SUSPENSIONS
TRANSMISSION
CHAIN525 0-RING
PERFORMANCE
DIMENSIONS/WEIGHT
SEAT HEIGHT810 mm
WHEELBASE1465 mm
WEIGHT258 kg
LENGTH2140 mm
HEIGHT1140 mm
WIDTH720 mm
ELECTRONICS
CONNECTIVITY
CHARGER
DASHBOARD
REVERSE MODE
COLORS
FOTO:
R200- Cantidad de envíos : 394
La foto que subio Mono es MUY diferente a las otras que estan posteando. Observen en la del video, como en la electrica ambas tienen suspension invertida, el manillar es mas bajo, espejos bajos, etc... Nada que ver con la primera posteada....
Saludos..
Saludos..
jorgeodo- Cantidad de envíos : 142
Fecha de inscripción : 30/03/2011
Localizacion : Catamarca
Exactamente , solo tienen un aire por asi decirlo pero no es el prototipo que puso en la foto el Mono. Asi que la moto del video es la electrica no es la 200SS
finalmente era la 375 osea la 400SS
♏㋡ℕ㋡- ADMINISTRADOR
- Cantidad de envíos : 6017
R200 escribió:La trompa me hace acordar a la cabeza de Bumblebee, jaja
La vi en amarillo. Confirmado! Los transformers existen y se hacen moto tambien.
» Nueva pulsar 200SS
» Dudas Sobre la Pulsar 200 2010 y ademas la Nueva Pulsar 135
» la nueva pulsar 150 as y 200 as??
» NUEVA PULSAR 180 UG
» Nueva Pulsar 375.
» Nueva Pulsar 375.
